Show your work. Including input and output. Maybe someone will help. First you should compare your input variables with the ones on the vendor sheet. And check some of the references you were given. They will have power calculation formulas.
Posted 21 June 2016 - 12:49 PM
Posted 19 July 2016 - 03:46 AM
Hi Bobby..
In my calculation now I am able to get pressure ratio and volumetric efficiency as same as software generated sheet. But still power(HP) is not matching with that sheet. Can you help me with equation of horse power calculation with some correction factor or Efficiency.
Brijesh
Posted 20 July 2016 - 03:10 PM
You need to check both mechanical efficiency and adiabatic efficiency. There are no mysteries to calculating theoretical adiabatic compression power requirements.
http://www.arielcorp...?TocPath=_____1
Edited by Bobby Strain, 21 July 2016 - 10:36 AM.
Posted 27 July 2016 - 07:32 AM
Hi bobby,
I am using efficiency value from this attached graph. This is from Book COMPRESSORS Selection and Sizing by ROYCE N BROWN. But still I am away from correct result.
Second thing is about frame friction. How to consider frame friction in calculated power. And in previouse performance sheet Stage power is (w/Friction). What is meaning of w/Friction.
Another confusion with effect on power due to valve loss. how to consider valve loss in power calculation
Brijesh
Edited by Brijesh Patel, 02 August 2016 - 03:08 AM.
Posted 03 August 2016 - 04:47 AM
Hi Bobby.
please reply for above mentioned question
I need help
Brijesh patel
Approach To Calculate The Overall Mass Transfer Coefficient In A RecirStarted by Guest_Basticcas_* , Today, 10:39 AM |
PressureStarted by Guest_guoyinyanliner_* , Yesterday, 04:58 AM |
Shell And Tube Pressure DropStarted by Guest_UofUChemE_* , 08 Jun 2018 |
