Hysys Convergence
hysys recycle convergence liquefaction hydrogen claude cylce
11 replies to this topic
#1 hamed2020
hamed2020
  • 9 posts
Posted 26 May 2016 - 01:44 PM
Hello everybody
I had simulated a simple Claude cycle for liquefaction of Hydrogen but unfortunately after completing the cycle I could not change the Feed conditions or other important parameter of cycle. In the case of changing parameters or Feed conditions I will face with the below mentioned error:
An Invalid math operation has occurred.
Insensitive error in HE
Error of consistency
I will attached my PFD and simulation file which is made in Hysys V7.2. If anyone know the problem please help me through this forum or my email: hamedrezaie20@yahoo.com
Attached File  HYSYS-Print.pdf   12.67KB   86 downloadsAttached File  complete simple claud.zip   69.73KB   45 downloads
Thanks to all
#2 Bobby Strain
Posted 26 May 2016 - 04:46 PM
Your simulation appears to have too many recycle operations. Analyze the process more thoroughly and determine where such operations should be used. And, you might need to add a controller operation somewhere. I am surprised that this simulation even ran.
#3 hamed2020
hamed2020
  • 9 posts
Posted 27 May 2016 - 01:49 PM
Thanks dear Bobby
I am a new comer to Hysys and this forum could you describe more, even I do not know what is controller operation?
Hamed
#4 Bobby Strain
Posted 27 May 2016 - 03:36 PM
Keep RCY-5. Move RCY-3 to stream 14. Remove the other recycles. You can then adjust the split of TEE-100 until you get a converged solution. Then study how to use the ADJUST operation to do this for you. This might work. If not, study the flowsheet carefully and make sure enough streams are defined to obtain a solution.
And you need to boost the operating pressure considerably. I would start at 10 bar on the compressor discharge.
Edited by Bobby Strain, 27 May 2016 - 05:19 PM.
#5 Mahdi1980
Mahdi1980
  • 182 posts
Posted 28 May 2016 - 08:52 AM
Hamed,
I have not checked your simulation file. However, it is clear that you have applied too many Recycle streams. As Bobby said, you should delete some excess Recycles. My suggestion is that you may omit the Recycles 4, 3, and 2 to simplify the simulation.
After running, if you intend to change the composition or other parameters please note that you should make changes on the correct side of the Recycle.
Let me know the result
Mahdi
#6 hamed2020
hamed2020
  • 9 posts
Posted 31 May 2016 - 01:06 PM
Hamed,
Mahdi
I tried to do as you and Mr Bobby mentioned but I was not able to converge the Cycle with to Recycle but I try more to do that. Thanks alot.
#7 hamed2020
hamed2020
  • 9 posts
Posted 08 June 2016 - 07:55 AM
Hamed,
Mahdi
Hi Dear Mahdi
I did as you mentioned and run the cycle with 2 Recycle but unfortunately it acts the same as before and with altering any parameter such as mass flow of feed or portion of each stream at TEE the consistency error will be appeared and the Cycle will not be converged.
I have attached the PFD to this reply.
Thanks to you
Hamed
#8 Bobby Strain
Posted 08 June 2016 - 09:00 AM
I mentioned pressure before. You still need to fix that, too. And you need to adjust the splitter to make it work. And liquid normally comes from the bottom of a separator. You should pay attention to such things.
Edited by Bobby Strain, 09 June 2016 - 02:17 PM.
#9 hamed2020
hamed2020
  • 9 posts
Posted 10 June 2016 - 06:08 AM
Dear Bobby I change the pressure many times and at the last model pressure at the output of compressor is 21 bar. Liquid comes out from the bottom of separator but the appearance of PFD I mirrored the separator about Y. I don't know where should I use adjus operation(between splitter and which set? based on which parameter?) please let me know in details.
Thank you
Hamed
#10 Bobby Strain
Posted 10 June 2016 - 08:52 AM
It's important that you display information properly. Bad habits seem to stick with you. That won't help you in your career. Change the split fractions with input and observe the result. Keep changing the pressure and observe the results.
#11 hamed2020
hamed2020
  • 9 posts
Posted 16 June 2016 - 07:46 AM
Hello
Fortunately I ran my cycle and I should give my spacial thanks to Dear Bobby and Mahdi. My final PFD is attached to this message.
#12 Bobby Strain
Posted 16 June 2016 - 09:04 AM
But the separator is still upside down. Don't start bad habits while you are still in school!  It seems to me that if this converges, you could remove one of the recycle blocks. The two you have are  essentially in the same stream.
