Greetings,
I'm designing a system where n-C4 is injected to a natural gas pipeline to achieve a certain mol% of C4 in the natural gas stream. GC reading (call it AE-1) will be taken 30 miles upstream of the injection point to determine the required injection rate, and a VFD on a diaphragm metering pump will be speed controlled to that flow. Another GC sample (AE-2) will be taken downstream of the injection point, to "verify" that the injection resulted in the correct mol%. I have the following questions regarding how to design a control loop of this system:
1) Since the flow rate is directly proportional to the VFD speed, is there a need to install an FIC on the discharge flow? Or can the speed of the pump directly controlled by a PLC logic based on AE-1 readings?
2) How can AE-2 readings be incorporated into the control loop? I'm thinking AE-1 going into a feedforward control of the motor speed that's somehow linked to a feedback control of AE-2 with the mol% setpoint. If someone could explain how this loop would actually work and shown on a P&ID, that would be very helpful.
Thank you in advance!
, (AE-1) (AE-2)
==============================================================> NG Pipeline
. C4 Injection
. (Metering Pump VFD controlled)
