Standards For Strainer Free Area And Pressure Drop
#1 samayaraj
samayaraj
  • 239 posts
Posted 15 June 2016 - 12:23 AM
Dear Experts,
For selecting strainers we generally follow the free area should be minimum 4 times the CSA of pipe and pressure drop across strainer will be 0.01 bar (clean) & 0.2 bar (50% clogged). Is there any standards available for specifying/selecting strainers? As far as I know there is no such standrads and its all based on good practice. I have browsed through our forum and it has nearly the same data as I mentioned above.
Please share your ideas. Thanks in advance.
Samayaraj
  • 6,769 posts
Posted 15 June 2016 - 12:42 AM
http://seperationtec...-and-strainers/
Hi Raj ,
Consider the resource above .
Note : You may find also interesting the calculator : http://www.pressure-drop.mobi/
Edited by breizh, 15 June 2016 - 12:45 AM.
#3 samayaraj
samayaraj
  • 239 posts
Posted 19 June 2016 - 03:56 AM
Mr. Breizh,
Thanks for your reply. My question is whether is there any standards for specifying strainers? As far as I know there is no such standards.
Edited by samayaraj, 19 June 2016 - 03:57 AM.
#4 fallah
  • 5,019 posts
Posted 19 June 2016 - 05:31 AM   Best Answer
samayaraj,
You are right, there is no specific standard to specify the strainers for various applications. Some companies have criteria for specifying strainers in their engineering practices...
#5 samayaraj
samayaraj
  • 239 posts
Posted 19 June 2016 - 08:13 AM
Thanks Mr. Fallah.
#6 Napo
Napo
  • 350 posts
Posted 12 February 2017 - 10:03 AM
Samayaraj,
Maybe You can review:
ASTM F1199 - 88(2015): Standard Specification for Cast (All Temperatures and Pressures) and Welded Pipe Line Strainers (150 psig and 150°F Maximum).
ASTM F1200 - 88(2016):Standard Specification for Fabricated (Welded) Pipe Line Strainers (Above 150 psig and 150°F).
Also API RP 686.
Napo.
