Cod Reduction From Effluent Stream Containing Dmso & Water
cod reduction dmso-water effluent solvent recovery
#1 hiren_d
hiren_d
  • 15 posts
Posted 15 July 2016 - 12:57 AM
I am working on COD reduction from effluent stream having following composition.
Water    :80%
Dimethyl Siulfoxide(DMSO) :11%
Ethyl Acetate   :8 %
Unknown Organic by products :1%
pH    :7-8
I need to recover & recycle DMSO out of the stream & send the water with low(minimum) COD for further treatment.
Desired composition:
Water stream: Maximum 1% DMSO content
Can anyone guide me to design the system for the stream?
Hiren Dave
  • 6,732 posts
Posted 15 July 2016 - 02:18 AM
Consider Google to support your query .you will find info about distillation of the mixture DMSO/Water .
#3 hiren_d
hiren_d
  • 15 posts
Posted 15 July 2016 - 03:43 AM
Hi Breizh,
Thanks for reply.
I tried Google.
Being Dilute stream (11% DMSO) it not cost effective to go with flash distillation.
I am looking forward to any Liquid liquid Extraction or Extractive distillation if anyone has deal with such situation.
Hiren Dave
#4 P.K.Rao
P.K.Rao
  • 265 posts
Posted 16 July 2016 - 04:05 AM
Try extraction with toluene. DMSO is soluble in toluene which can be separated from water..
#5 breizh
  • 6,732 posts
Posted 16 July 2016 - 07:55 PM
Hi .
Other solvent : Di-Isopropyl ether .
#6 hiren_d
hiren_d
  • 15 posts
Posted 22 July 2016 - 03:56 AM
OK. Thanks .
I will check & revert.
#7 hiren_d
hiren_d
  • 15 posts
Posted 25 July 2016 - 05:04 AM
Dear sir,
I have tried with toluene & dichloromethane both are practically insoluble in water.
But unable to extract DMSO out of water.
Both layers weight remain as it is.
Any other suggestion?
