Hi everybody,
I´d like to ask you about a very big doubt a have about the interpretation of tables 2.8a and 2.8b of the API MPMS Ch. 14.3.2 or /AGA Report No. 3, part 1.
Intro:
At the moment you have to design your pipeline layout process engineer MUST work with mechanic engineer to define the minimum required meter tube lengths for meters with 1998 Uniform Concentric 19-Tube Bundle Flow Straightener.
Manual API MPMS Ch. 14.3.2 gives tables 2.8a and 2.8b to help the engineer. Those tables are based on Figure 2-6 of the manual (Attached as Figure 2-6).
Figure 2-6.JPG 26.92KB
0 downloads
Doubts:
I have two-mayor doubt about those tables:
1) Once you have decide to install a 1998 Uniform Concentric 19-Tube Bundle Flow Straightener , which would be the criteria to decide between table 2.8a (17Di < UL < 29Di) and 2.8b (UL > 29D). Only your plot plan design?
2) Those tables gives a “range” of distance? Let’s see the case of a “Single 90° elbow R/Di = 1.5” of table 2.8b. It recommend you a 5-25 range. (Attached as figure 1).
Figure 1.JPG 100.21KB
1 downloads
Which is the real distance for UL? Is 5Di o is a 25Di?. For a 6in meter, you have 924mm and 3850mm respectively. It´s a big difference!
Can anybody help me?
Thanks in advance
Ariel
