Edited by SadiqChemy, 20 May 2017 - 11:48 PM.
Deleted
Posted 29 July 2016 - 08:28 AM
Posted 29 July 2016 - 10:16 AM
Besides your lack of training in mechanical design and metallurgy, are you a "class A" welder? Have you ever "burned a rod"? Are you knowledgeable with regards to welding machines and how / where they are employed?
If not, then I wouldn't think of assigning you to inspect a weld and much less to approve it.
I state the above with some bias because I worked summers through college years as a boilermaker in a shipyard, welding a lot of plate metal. I learned to weld in the shipyard and worked besides a lot of expert electric arc welders. Welding is an acquired skill that even some mechanical engineers are ignorant of. It is a skill that demands a lot of practice and experience in its applications as well as in its inspections.
Posted 29 July 2016 - 11:59 AM
I have never welded before. I didn't have any basics of welding before I joined the company even I didn't know the meaning of welding! I've been working at company since April! Most of the time I am idle and the give me simple things.
So I consider to request them transferring me to another department that are more suitable for me !
Posted 29 July 2016 - 02:07 PM
In my opinion you are doing the best thing for you - and for your employer.
I don't consider it fair to you personally and to your future career as a chemical engineer to expect you to take on an important and critical responsibility such as weld inspections without having the experience, training, and preparations necessary for such a critical job.
Whoever is proposing that kind of assignment for you, without the proper training and experience is, in my opinion, asking the impossible of you and sending you on a path directly to failure and a bad mark on your future career.
Good Luck.
DeletedStarted by Guest_thereyougo123_* , 07 Dec 2022 |
DeletedStarted by Guest_Saml_* , 20 Jul 2022 |
DeletedStarted by Guest_cheme0037_* , 07 Dec 2020 |
DeletedStarted by Guest_Pingue2008_* , 10 Jan 2014 |
DeletedStarted by Guest_go-fish_* , 25 Oct 2011 |
