Venting -Api 2000-(March 2014)
7 replies to this topic
#1 Guaiamum
Guaiamum
  • 3 posts
Posted 11 August 2016 - 08:01 AM
Dear Friends!
I have a 15000 m3 "API 650 Tank", and I must choice a  "Flame Arrester" for it. The product is an heavy fuel oil, and the maximum temperature inside the tank is 80 ºC.
By API 2000 (2014), the vapor being displaced in outbreathing shall be converted to an equivalent flow of air at normal or standard conditions, because the tank is operating above 120 ºF (49 ºC). And for doing so, I must know the molecular weight of that vapor in the actual conditions of pressure (1,85 inch/water column), and temperature (80 ºC), to enter the API formula.
My question is : how can I obtain such value?! It seems impossible to me to find the necessary data, but maybe someone will be so kind and teach me how to "solve this mistery"!!
Best Regards
Guaiamum
#2 chocobang
chocobang
  • 64 posts
Posted 11 August 2016 - 11:15 PM
This mystery is not mystery at all.
Use air if there is no blanketing, or use blanketing gas molecular weight. It does not change with pressure and temperature.
If you have the latest version (7th Ed) of API 2000, go to Table D.1 (see comments). Air is used for less than 49degC. It is implied to use air for greater than 49 degC if you truly have no blanketing gas for the tank.
Don't forget to include both thermal and normal for your flame arrester.
#3 Guaiamum
Guaiamum
  • 3 posts
Posted 12 August 2016 - 03:48 AM
Dear christopherchoa
Thank you for your answer.
However, from Table D.1, and for outbreathing (free vent), I understood that air is only permitted if the tank temperature is less than 49 ºC. If it is greater than that, then threre will be a mixture of air and vapor of the tank contents ("fuel vapors", in this case), that we shall take into account.
And that is my "problem" : how can I find the properties of that vapors? Namely specif weight, and molecular weight, to enter the formula D.37, to convert to an air-equivalent flow at normal or standard conditions?
I am saying anything stupid?
Thanks for the help.
Best Regards
Guaiamum
#4 chocobang
chocobang
  • 64 posts
Posted 12 August 2016 - 10:46 PM
Guaiaman,
I think you are right and I am wrong. hehe. Your interpretation is logical.
Let me get back to you as I look more into the standard next week.
#5 Guaiamum
Guaiamum
  • 3 posts
Posted 13 August 2016 - 06:27 PM
Dear Christopherchoa
Thank you again for your help and time.
Best Regards
#6 Usama Khan
Usama Khan
Posted 07 September 2016 - 12:58 AM
Dear Friends
My question is :  How can we calculate the size of Vapor equalizer line and Vent line in LPG system?
please guide me.
#7 chocobang
chocobang
  • 64 posts
Posted 15 September 2016 - 09:35 PM
Hi Guaiaman,
Can you use Equation D.36, D.37 (API 2000 2014 Edition)? Simplified conversion equations
How did you resolve this problem?
Christopher
#8 ana ibarra
ana ibarra
Posted 22 May 2017 - 01:09 PM
estimados, alguien me puede pasar el archivo PDF del API 2000 7a. edición
Saludos.
