I am using a non agitated pressure vessel with half pipe coil outside for heating the mass. What will be the heat transfer coefficient of inside vessel, if i am boiling or heating the inside mass.
ND.
Posted 12 August 2016 - 12:26 AM
ND.
Posted 10 October 2016 - 11:51 AM
NBD300,
You can review the book of Kern, Process Heat Transfers, Ch. 10, p. 214 and following.
Napo.
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
