Minimum Distances Between Equipments
Posted 16 August 2016 - 01:51 AM
So I want help to select distance between equipments??
Posted 16 August 2016 - 09:43 AM
There is no single guideline. Much depends on the hazards of your process and the space available. Refineries may have different criteria than chemical plants. Spacing may be extremely tight on ships or offshore platforms. At a minimum you should have room for maintenance access. Consider the need for crane access or forklift access. Heat exchangers with removable bundles should have enough space to work the bundle out. Some vessels need a large diked area to contain leakage. Fired equipment and flares need their own space to keep open flames from igniting accidental flammable vapor clouds. Your piping will not always go directly from equipment to equipment, but often to a pipe rack which serves as a main highway through your plant. Web-search "process plant plot plan" to find good reference material.
Posted 19 August 2016 - 05:50 AM
Posted 14 November 2016 - 03:58 PM
Zohaib Siddiqui,
If not too late, you can ckeck the Data Engineering Book by GPSA, Chapter: Utilities.
Napo.
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
![]() Minimum Tower DiameterStarted by Guest_AnbIran_* , 17 Nov 2023 |
Minimum Vapour Headspace For N2 BlanketingStarted by Guest_go-fish_* , 07 Jan 2023 |
High Pressure Drop Across Liquid Pipeline At Minimum Flowrate Case . VStarted by Guest_hariz-process_* , 03 Jun 2021 |
Pump Minimum Flow Control Philosophy QueryStarted by Guest_rs20170808@gmail.com_* , 23 Oct 2018 |
