Mass Of Cooling Water And Time Required To Cool Aluminium Slab.
Posted 16 August 2016 - 04:56 AM
Posted 16 August 2016 - 11:13 PM
Your problem is related to "Transient heat transfer". You have to mention more details about the dimension of aluminium slab, water temperature after quenching, etc. I hope, its kind of quenching application where large pool of water is available and hot aluminium is quenched. I am not sure how you can use chilled water here (diff in temp is near 100 Deg. C).
Look at the below link for your reference.
http://web.iitd.ac.i...-conduction.pdf
http://web.mit.edu/1...es/node129.html
Edited by samayaraj, 16 August 2016 - 11:17 PM.
Posted 18 August 2016 - 12:41 AM
Thank you Mr. samayaraj for your reply.
Actually cooling is done through cooling water but Chilled water is used in heat exchange to maintain cooling water temperature.
I have requested for temperature of cooling water after quenching but they replied that
"Maximum Temperature of Cooling water after touching 105 Degc AL can be calculated based upon retention time of cooling tub."
Please find below dimensions for Aluminium Ingot
Thickness: 635 mm
Ingot Width: 1613 mm and 1828 mm
Length: 9000 mm
Weight: 30000 Kg
Shawkat
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Cool Hot Air By Adding Ambient AirStarted by Guest_Santoshp9_* , 02 Dec 2025 |
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
