All;
Is there any criteria for the distances between two expansion loops in one pipe line? and how can i decide if the pipe line needs one or more expansion loops?
Mohamed
Posted 18 August 2016 - 03:45 AM
All;
Mohamed
Posted 18 August 2016 - 04:59 AM
mgamil24,
Yes, there is. It depends on several parameters such as: maximum temperature, pipe material, linear thermal expansion factor of the pipe,...
You can refer to piping design handbook section of supporting the piping subject to movement due to thermal expansion...
Edited by fallah, 18 August 2016 - 05:00 AM.
Posted 19 August 2016 - 03:24 AM
Fallah;
Thanks a lot for responding - i working on the book now but the maximum temperature you mentioned is Operating or design?
Mohamed
Posted 19 August 2016 - 07:52 PM
Mohamed,
Although in many cases it might to be conservative, the design temperature is normally to be used...
Secondary Heating Loop For ReactorStarted by Guest_TheChemEng_* , 28 Nov 2024 |
![]() Ammonia Synthesis Loop SimulationStarted by Guest_Said Salim_* , 05 Apr 2017 |
![]() Closed Loop Pump Suction Line Sizing CriteriaStarted by Guest_Afshin445_* , 30 Aug 2024 |
![]() Fire Case Gas Expansion (Gas Filled & No Liquid)Started by Guest_moosa.akbar_* , 27 Aug 2024 |
