> Loop $OLVER03 Method: WEGSTEIN Iteration 30 Converging tear streams: S4 S14 S21 S24 * WARNING CONVERGENCE BLOCK $OLVER03 NOT CONVERGED IN 30 ITERATIONS 53 vars not converged, Max Err/Tol 0.45053E+02 ** ERROR Convergence block $OLVER03 did not converge normally in the final pass
Error In Aspen Plus Pleas Help Me
Posted 30 September 2016 - 08:28 AM
Posted 01 October 2016 - 01:23 PM
Not much information to even guess what your problem may be. It only says that the error, when closing the loop in streams S4/S14/S2 and S24, is higher than the tolerance.
One common issue is that the flash tolerance is high when you have multiple units so when you come back to the tear stream you have a sum of errors that is higher than the tear tolerance. Try setting the flash tolerance spec to a lower value.
But may be because of intermediate errors, unfeasible specs, that the convergence algorithm cannot solve this particular problem, that has slow convergence and you need more than 30 iterations, that you started far from a solution and you need to initialize, etc, etc, etc...
Edited by Saml, 01 October 2016 - 01:24 PM.
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Sigma Profile For Cosmo-Sac In Aspen PlusStarted by Guest_R.t_* , 14 Aug 2025 |
How To Model The Bitumen In Aspen Plus?Started by Guest_engrbab01_* , 28 Jul 2025 |
