Can anyone guide me to have good correlations or equations to measure the pressure drop of non-newtonian two-phase flow in the pipeline?
Posted 22 October 2016 - 04:49 AM
Posted 25 October 2016 - 05:02 PM
Posted 25 October 2016 - 10:23 PM
Posted 25 October 2016 - 10:32 PM
Siraj77,
Can you give the non-newtonian type you work?
Also, the pipe is horizontal or vertical?.
Napo.
It's Xanthan gum solution, shear thinning fluid.
The pipe is horizontal.
Posted 25 October 2016 - 11:48 PM
Thanks a lot
Posted 26 October 2016 - 07:15 PM
Posted 30 October 2016 - 04:35 AM
hi,
A few other documents
http://fekete.com/SA...alculations.htm
Hope thsi helps .
Edited by breizh, 30 October 2016 - 04:39 AM.
Posted 30 October 2016 - 03:37 PM
Great thanks guys! I appreciate it.
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
