Distillation Column Cleaning
#1 Eprocess
Eprocess
  • 45 posts
Posted 17 November 2016 - 09:38 AM
Hello
We have a distillation column which is used to distill diesel from a mixture containing biomass and oil. The solids build up in the column is pretty bad. We flush the column every week with solvent and diesel mixture but the way is done is not effective (very low flow rates) and the duration is very short as well. It is sieve tray column and we have 15% solids in our feed. I was wondering if anyone knows any references for procedures on cleaning distillation columns. I am thinking about a more effective method which can be done less frequently like those are done in oil refineries. Would appreciate if someone with similar experience could help me out as we have a small demonstration plant.
Thank you
  • 1,576 posts
Posted 17 November 2016 - 10:46 AM
You might begin researching what ITW offers to get some ideas:
http://www.digitalre...e_Cleaning.html
#3 Bobby Strain
Posted 17 November 2016 - 12:26 PM
I would be inclined to replace the sieve trays with dual flow trays. Also, you should look to the fermenting industry for their solutions. Harvey Wilson can probably provide the best advice.
#4 sgkim
sgkim
  • 289 posts
Posted 21 November 2016 - 05:55 AM
I once designed a fermentation plant, and found a 'HYDRA SIEVE" was a good choice to remove the solids quite simply.  You'd rather remove the solids before the mixture comes into the column.
Search the internet sites with the keyword "hydra sieve" - for example, the following:   http://www.directind...603-507950.html
~Stefano(sgkim)
