Amine Absorber Simulation In Aspen Hysys
aspen hysys mea sourgas
#1 Siqma
Siqma
  • 4 posts
Posted 19 November 2016 - 12:26 PM
I want to simulation a SourGas absorber in Aspen Hysys.
But it I cant converge it. Help Me...
#2 Spancer
Spancer
Posted 14 December 2016 - 01:44 AM
According to your diagram, firstly you should define the lean amine circulation rate according to the acid gas you want remove, the calculation sheet is provided by cheresource according to GPSA databook,you could downloaded it freely. The temp of the sour gas is proper, you should adjust the temp of lean amine ,may be 6 ℃ upper than the feed gas(if utility is available). i donot know your hysys versions, may be if you attatched your model, i can help you.
