Hello everyone
I would like to know the formula for polytropic head calculation in HYSYS. Does any body know that?
Posted 28 November 2016 - 10:38 AM
Hello everyone
Posted 28 November 2016 - 05:51 PM
I don't believe HYSYS uses a formula. The calculation for compressor parameters is accomplished using an equation of state of your choosing. You should find some background in your users manual.
Posted 29 November 2016 - 12:58 PM Best Answer
Mohsen,
Gas thermodynamic laws are derived from first principles of physics and whether the calculation is done on a piece of paper, in excel or using a simulation software the equations remain the same.
However, if you are looking to a quick reference for a formula, refer the link below (post #11):
http://www.cheresour...mpressor-power/
And you will find the same in HYSYS or any other simulation software for a given set of units.
Posted 29 November 2016 - 03:28 PM
Mohsen,
Thanks a lot dear Ankur.
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
![]() Discharge Head Or Differential Head, Pump CurveStarted by Guest_panoska_* , 11 Nov 2024 |
![]() Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
Floating Head Rule For Shell And Tube ExchangerStarted by Guest_Ghasem.Bashiri_* , 06 Dec 2023 |
