Foaming In Amine Absorber
#1 Kranthi Kiran
Kranthi Kiran
Posted 30 November 2016 - 04:50 PM
Does DP type LT's malfunction when foaming occurs in an amine absorber in gas sweetening unit..?
#2 Bobby Strain
Posted 30 November 2016 - 10:33 PM
Not when properly installed.
#3 breizh
  • 6,886 posts
Posted 30 November 2016 - 10:51 PM
Definitely the foam is going to modify the density of the liquid thus the level .
Use the search engine in this forum , this subject is discussed .
Hope this helps.
Edited by breizh, 30 November 2016 - 11:12 PM.
#4 sgkim
sgkim
  • 289 posts
Posted 01 December 2016 - 02:54 AM
Hi Kranthi,
Compared with the various other types such as ultrasonic or capacitive, the differential pressure(DP) or float type sensors are less sensitive to foams.  When foaming occurs, the bottom level may usually drop not because of malfunction but because of column loading on each stage of the absorber.  The functionality of LT can be checked by local level gauges.
sgkim
Edited by sgkim, 01 December 2016 - 02:54 AM.
