- We have two compressors of 6Millions of capacity each one. The Nominal value is 11 Millions Standard cubic meters of natural gas for the plant to run, so the flow is divided into two : 5.5 MMSCM for each machine ( in the normal situation).
- Now, we're running with 8-9 Millions, and the anti-surge of the tubine on mode suction is open all the time (6-9 % open) , So, in order to close the anti-surge valvle of this machine, I opened the valve that can recycle the outlet-gas to enter again the plant, so that the anti-surge valve can close. Because I think it's good for the stability of the machine.
So what do you think? is it okey for the anti-surge valve to keep open all the time? or what I did was better ?
Thank you!
