Allowable Overpressure And Overpressure Factor
7 replies to this topic
#1 shahidulislam48
shahidulislam48
  • 104 posts
Posted 03 December 2016 - 05:22 AM
Recently, I have been doing work on PSV datasheet that have to be filled up by "Allowable over pressure (%)" and "Over pressure Factor" . But it gets me really confusing to differentiate between these two parameters. As far as I know, these two parameters are quite same!
If someone could enlighten me about this I would be very grateful.
Many Thanks,
#2 fallah
  • 5,019 posts
Posted 03 December 2016 - 07:47 AM
They could be different...
Overpressure factor is the factor of the pressure exceeding over the design pressure...
Allowable overpressure is the percent of the pressure over the design pressure to reach the 1.1 times of MAWP (1.21 for fire case)...
For example if design pressure is 90 barg and MAWP is 100 barg, then the normal overpressure factor can be 10% over the design pressure to reach 99 barg (still lower than MAWP) and at the same time allowable over pressure would be around 22.2% ((20/90)*100)...
#3 latexman
  • 1,841 posts
Posted 03 December 2016 - 08:23 AM
I think the confusion comes from not strictly adhering to the definitions of the applicable Code.  I suspect the datasheet writer confused "overpressure" with "accumulation" in one place and adding the extraneous word "factor" in another.  I recommend re-reading the instructions or procedure that accompanies the datasheet, and having a discussion with the datasheet  author.
Edited by latexman, 03 December 2016 - 08:25 AM.
#4 shahidulislam48
shahidulislam48
  • 104 posts
Posted 03 December 2016 - 09:33 AM
Dear Fallah, thank you for your solution and helping me to understand the facts clearly.
And also thanks to "Latexman" for figuring out the main problem for us.
If I don't get misinterpretation, in Fallah's statement, Design Pressure = Set Pressure, and it could be possible that Design Pressure = Set Pressure = MAWP. Then,
Relieving Pressure = Set Pressure + Allowable Over Pressure + Atmospheric Pressure
I would be grateful to know about the Required Capacity in Barg as I'm wondering that capacity in pressure unit!!. If it is ok then pressure will be the relieving pressure.
If I'm wrong please help me.
shahidulislam48
#5 fallah
  • 5,019 posts
Posted 03 December 2016 - 10:42 AM
PSV required capacity should be in kg/hr or m3/hr units. Then the pressure units can not be applied to PSV capacity.
#6 shahidulislam48
shahidulislam48
  • 104 posts
Posted 03 December 2016 - 12:23 PM
Dear Fallah, could you please look at the attached file of datasheet portion?
What does the marked one really mean?
#7 fallah
  • 5,019 posts
Posted 03 December 2016 - 12:56 PM
At first please specify what does the "DEDT" in data sheets stand for?
#8 shahidulislam48
shahidulislam48
  • 104 posts
Posted 03 December 2016 - 09:56 PM
DETD = Detail Engineer to Determine
I am doing detail engineering.
