For drying of compressed air dessicant is to be selected, what forms the basis.
Silica Gel And Molecular Sieve Selection Basis
Started by rsk, Dec 04 2016 01:15 AM
Posted 04 December 2016 - 01:15 AM
Posted 05 December 2016 - 08:52 PM
RSK:
When selecting the type of adsorbent (which is what you mean) to be used in gas drying service, you should rely on:
- Your experience with the individual adsorbents being considered;
- The drying service to be imposed on the adsorbent - what product dew point are you targeting? What is the nature of the gas to be dried?
- What is the operating pressure and temperature?
- What type of adsorber unit design are you evaluating? - is it a "heat less" type? Is it a heat regenerated type? Is it a PSA type? etc., etc.
- Are you going to base your decision on adsorbent price? Or on performance?
- Can you tolerate dusting or adsorbent breakdown? If so, go with silica gel - the cheapest and the most prone to dust.
- How clean is your process gas?
- What type of regeneration system are you employing?
There are more items that come into play, but the above should suffice with the general nature of your query.
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
