Constant Backpressure
#1 shahidulislam48
shahidulislam48
  • 104 posts
Posted 11 December 2016 - 07:11 AM
Can anyone help me to find out the constant back pressure of Rupture Disk of the following system?
If I am not wrong, I guess it will be 1 barg.
Attached File  DSC_0011.JPG   39.85KB   2 downloads
Many Thanks.
#2 fallah
  • 5,026 posts
Posted 11 December 2016 - 08:13 AM
It is normally 0 barg which can be monitored by a PG to check about the leakage occurrence. But, as a RD is a differential pressure device, if it's intended to be 1 barg it should be considered in its burst pressure...
#3 shahidulislam48
shahidulislam48
  • 104 posts
Posted 11 December 2016 - 01:21 PM
If I think that before the installation of PSV, the back pressure that has been experienced by the RD is from the K.O. drum and constant.
If then I install PSV, fluid that have been trapped inside pipeline of length h, will provide the same back pressure as before to the RD.
That is how I came up with 1 barg.
It is true that during the installation of PSV, RD will expose to atmosphere and will have constant back pressure of 0 barg.
Thanks.
