Flow Through An Existing Control Valve Estimation
#1 Said Salim
Said Salim
  • 98 posts
Posted 21 December 2016 - 05:06 AM
I am aiming to calculate the flow of natural gas through the attached control valve datasheet. (Estimation of NG going to a flare)
Pressure drop across the valve is known (72.11 Bar) and the valve opening is 50% with linear characteristic. All fluid upstream downstream properties of the control valve are known.
Can anyone guide me how to perform the calculations? or can guide to any site that will serve my purpose.?
#2 latexman
  • 1,836 posts
Posted 21 December 2016 - 07:41 AM
Have you tried the website of the control valve vendor?  Maybe there is technical documents in the equipment files that has sizing methodology?  One of my "go to" websites on control valves is Fisher Controls.  Google it and drill down to their sizing documentation.
#3 raju.kct
raju.kct
  • 11 posts
Posted 21 December 2016 - 12:43 PM
Hi Said,
The flow of gas through a system is a function of inlet and outlet boundary conditions and other components pressure drop of the system.
I assume, the control valve is one of the component, which alone will not decide the flow rate.
May refer any Fluid mechanics text book for pipe loss calculations.
#4 Elfaghi
Elfaghi
Posted 22 December 2016 - 04:09 PM
you can deal with it, as the gas flows through an orifice plate by assuming the ratio of opening valve is the hole of orifice plate, and do your calculations (it is an estimate method)
GOOD LUCK
Ashraf
Edited by Elfaghi, 22 December 2016 - 04:10 PM.
#5 ecas
ecas
  • 12 posts
Posted 10 February 2017 - 04:06 AM
Use the following equation: W(kg/h) = 23.3[Valve Preesure Drop (bar) x Gas Density (kg/m3)]0.5Cv
The valve flow coefficient Cv comes from your valve data sheet. As the valve characteristic is linear and your Cv with 100 % opening is 2.55, at 50 % opening the Cv = 0.5x2.55 = 1.275
Find in Google the Emerson/Fisher Valve Handbook, it's free.
