LSVR is heated by MP steam (14 KG/cm2 g) before being used as fuel in furnace. MP steam inlet line is not having automated control system at the inlet of heat exchanger. At the inlet there are one gate valve and one globe valve with blind and drain arrangement. At the downstream of heat exchanger there are steam traps in one operating and one standby mode. MP steam is in tube side and LSVR in shall side. LSVR Viscosity which can furnace burner handle is 20cst which can be achieved once LSVR temperature reached 160 degree C (thermocouple is provided on LSVR outlet).
Is it a good design or any change is required in MP steam control?
Kindly reply.
Lsvr Using As Fuel Oil In Furnace Will Be Preheated By Mp Steam In A H
Started by Mayank_process engineer, Dec 24 2016 03:02 AM
No replies to this topic
Posted 24 December 2016 - 03:02 AM
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
