Vapor Pressure Exception Vs. Vapor Pressure Waiver
gasoline vapor pressure waiver exception
#1 Tolinorton
Tolinorton
  • 73 posts
Posted 02 January 2017 - 03:15 AM
What is the difference between Vapor pressure exception and Vapor pressure waiver of gasoline.
  • 1,634 posts
Posted 03 January 2017 - 12:56 PM   Best Answer
If I understand your question correctly, I explain it like this:
Gasoline has vapor pressure specifications. But when ethanol is included in gasoline, the normal vapor pressure specifications are difficult to meet.  So there is an allowable exception to those specifications when ethanol is in the gasoline. Even with ethanol in the gasoline there are still vapor pressure specifications that must be met based on the amount of the ethanol component. The amount of ethanol determines how much higher vapor pressure is allowed. The revised vapor pressure spec value is calculated from the table you attached. This new vapor pressure is specific to the composition of your gasoline and is the amount of 'vapor pressure waiver' allowed if the gasoline does not meet the normal gasoline spec.
#3 Tolinorton
Tolinorton
  • 73 posts
Posted 04 January 2017 - 11:14 AM
Dear Pilesar,
Thank you so much for the answer, I just wanted to know is there nay differences between Vapor Pressure Exception and Vapor Pressure Waiver.
