QUOTE
I have not reviewed Pervaporation. If U know some supplier who is providing this Tech for MEG Water system, Pls let me know.
I am not really very clear on the term Infinitely OR No solubility. What is the meaning of the crystallization curve in that case. Any binary system is essentially having some boundary conditions where the two components separate out.
If U say as above that EG has no solubility in water - what do you read from the attached curve.
Let me put it again.
Well if I start with 10% MEG & Chill the solution to say -22°C or so then there should be 2 phases - Solid phase will be water freezed out of solution & remaining solution will be ~40% MEG at that temperature. Is it not correct?
Why I am looking for it is that the size of my requirement is ~100 M3/hr of 12% MEG. Which will result in 4 Million USD/yr saving.
(1) Multi-effect evaporation
In multi-effect evaporation, the heat of vaporization of water is to be used for the evaporation of feed MEG solution, thus the steam consumption can be minimized. Energy consumption depends on the number of evaporators, but it shall be compromized with the additional equipment cost.
(2) Pervaporation
As the word implies, pervaporation uses selective membranes thru which water permeates and vaporizes. Presently I doubt on the economics of the pervaporative dehydration of MEG solution because of the cost of membrane. As the cost of energy soar up, however, it will surely become prevalent in the near future.
If you are not famliar with this, search on the web or refer to the following material for the pervaporation:
http://www.ingentaco...6d7qg0ru2.alice(3) Infinite Solubility vs. No Solubility
I am sure you know, better than me, the solubility of MEG in water. Solubility is generally defined as the maximum quantity of a solute dissolved in 100 gr of a solvent at a certain temperature. And the solubility usually increases with themperature. You know any quantity of MEG dissolves in 100 gram of water(i.e. infinite solubility of MEG in water). Moreover any quantity of water dissolves in 100g of MEG(i.e. inflinite solubility of water in MEG). So MEG or water has NO DEFINITE solubility in each other. That's why I expressed as "NO SOLUBILITY" or "INFINITE SOLUBILITY" - both means the same, I'd say.
(4) Freezing Curve vs. Solubility
QUOTE
What you had attched on your first posting is "Freezingpoint Curve" and by no means "Solubility Curve" that you may call it. You and I did not read the "Saturation Point" but "Freezing Point" of the solution.
(5) Solid of MEG Solution at Freezing Point - MEG-pure Crystal or Not ?
QUOTE
If you chill the 10% MEG solution down to say -22°C, part of the solution will start to form "SOLID" in the solution. But the "SOLID" formed in the solution is not definitely MEG-pure, but MEG-Water mixed solid.
I remember the solid was just like the ICE-CAKE BAR. The SOLID, thererfore is NOT "MEG-pure Crystal".
So your understanding " Pure (or more concentrated) MEG Crystal would be formed leaving the more dilute MEG solution as solution " is NOT correct.
Note i) Freezing means neither Crystallization nor Saturation.
ii) Crystallization is not in the dictionary of MEG-Water solution.
(6)
QUOTE
The process being not yet selected, how come to know the figure of annual saving 4 MM USD ?
To fix the figure, what will be the maximum investment cost? Interesting..
Stefano
