I need articles/literature on flow induced vibration in valves and piping. Can someone help me out?
Flow Induced Vibration
Started by mahuda, Mar 29 2003 11:32 AM
Posted 29 March 2003 - 11:32 AM
Posted 11 April 2003 - 01:40 PM
mahuda....
The only source of information I have found addressing piping vibration is the "Shock & Vibration Handbook".
ASME B31.1 and B31.3 state that vibration should be minimized.....but offer no guideance.
Some companies perform a computerized dynamic analysis of the system, then find the locations wher the piping is "most likely to displace and vibrate". They then install pipe restraints at this location.
Check the www.eng-tips.com bulletin board.
I believe a Mr. John Breen had some posts about piping vibration there....
MJC
MJC
Posted 13 April 2003 - 12:51 PM
Thanks a lot...MJC
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
