Dear friends,
One of my projects is the handling of some powder additives from a hopper to an extruder which is located far from the hopper and for this reason, I have to use two screw conveyors. The additives are materials like antioxidants, anti blocking , anti sleep agents and etc some of which are sticky so that they cannot be handled by other types of conveyors.
As you know, for conveying the powder materials by more than one conveyor, the rotational speed of them to be increased one by one up to downstream to avoid accumulation and chocking through the path.
You are requested to propose a rule to determine the minimum or normal speed ratio of these screw conveyors. For instance, if the speed of the first conveyor is 10 rpm what is the proper speed of the second one, 15 m/s, 20 m/s or higher. If someone has a book, paper or standard as a reference or has any experience on this issue, I appreciate him/her for sending to me or post it here.
Email: mahdi80@gmail.com
Thank you in advance,
