I have to compare the different heat transfer equipment on the basis of their thermal efficiency. can anyone help me
Posted 02 February 2017 - 05:04 AM
Posted 02 February 2017 - 09:33 AM
The efficiency is defined as the ratio of the quantity of heat removed from a fluid to the maximum that could have been removed. You can find the equation in Kern or any other book on Process Heat Transfer.
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
![]() Final Composition Calculation Of First Iteration Of Methane Steam RefoStarted by Guest_kikisapsal_* , 14 Sep 2024 |
