I am currently working on design a project of a shale gas processing plant. And I reached point where I need to calculate the energy balance of the worst case scenario for the plant [ To check the feasibility of the plant before integrating the utilities], the problem is that I am not sure how to carry out the energy balance as I have all the process operating at 10 bar and above. Is it only a matter of finding the actual value of heat capacity through the reduced pressure and temperature and then calculating the enthalpy based on that value?
Faisal.
