Data to draw the binodal stability curve is given. The feed(xF ,F) and solvent(xS ,S)flow rate and composition are also given. How can I calculate raffinate(xR) and extract(xE) phase composition?
Posted 05 February 2017 - 01:28 AM
Posted 05 February 2017 - 02:07 AM Best Answer
hi ,
Consider this resource
other videos are available on youtube.
note : You should start with mass balances ( global and species )
Edited by breizh, 05 February 2017 - 03:08 AM.
Posted 05 February 2017 - 03:28 AM
In my problem, I have four variables and three equations, that's where my problem lies.
Variables: R, E, xR , xE
Equations: 1. xF = xR*R + xE*E (Solute Balance)
2. S = (1-xE)*E (Solvent Balance)
3. (1-xF)*F = (1-xR)*R (Carrier Balance)
And actually, raffinate and extract both with have all three of them because both the point has to lie on the given binodal curve. Basically, I have to draw a tie line but I cannot get the required points of Raffinate and Extract.
Posted 05 February 2017 - 06:32 AM
I previously stated that you should consider youtube to support your work . Key words liquid liquid extraction .
additional ressource is attached .
Edited by breizh, 05 February 2017 - 07:53 AM.
Pressurizing LiquidStarted by Guest_Ahmadhamzahperta_* , 02 Apr 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
