I was asked to select a pump used to push liquid propane from a storage tank to a process vessel. The pump is used intermittently - for perhaps an hour at a time every few weeks.
Currently, the application uses a sliding vane pump. It is a simple set up - the propane travels from the storage tank, through the pump, to the process vessel. There is no recirculation line.
The storage tank is not heated, so in winter, the low vapor pressure in the tank means that the suction pressure to the tank is low, and the discharge pressure from the pump does not get high enough to push the propane into the process vessel.
I contacted the original pump vendor, but there are no upgrades that we can make to the existing sliding vane pump to increase the discharge head. Instead, the vendor recommended a multi-stage centrifugal pump.
Is it common to use multi-stage centrifugal pumps in intermittent service? It seems like I would at least need to add a recirculation line to ensure minimum flow for the start-up and shut-down.
I appreciate any advice you have, as I don't have a lot of experience with multi-stage centrifugal pumps. I've only seen them in continuous flow applications.
