I'm currently attempting to model a PSA column to separate hydrogen from CO2,N2,O2,CO but I can't seem to find an adsorption unit in HYSYS
Is this possible or should I use another program?
Cheers
Posted 13 February 2017 - 10:21 AM
Cheers
Posted 13 February 2017 - 12:42 PM
mission impossible ;-)
good luck
Posted 14 February 2017 - 04:00 AM
peng-eng,
When someone is normally building a simulation model, there is an end objective. For example, if you are building an exchanger model, maybe you want to find out the duty, or it fouling etc. In your PSA column, what are you trying to calculate? A PSA unit does not normally consume energy as such.
If the PSA in the process (which you are trying to simulate) is a purification step, you can make use of the spreadsheet to calculate the downstream composition (based on the PSA feed stream composition) and let that carry onward as a feed stream to your downstream process.
Are you trying to calculate some other parameter?
Posted 14 February 2017 - 06:32 AM
peng-eng,
I'm trying to model a purification step, I've decided to use a component splitter instead to simplify matters.
Cheers
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
