Test Separator
#1 Process Engineer 90
Process Engineer 90
  • 9 posts
Posted 14 February 2017 - 10:48 AM
Hi everyone
I am sizing a new test separator but there is a few problems like the location of the level gauges,level transmeters, pressure gauge and pressure transmeter.
The location of the oil and water outlets.
If any one can help me I will be very grateful.
Edited by Process Engineer 90, 14 February 2017 - 10:56 AM.
#2 Bobby Strain
Posted 14 February 2017 - 05:18 PM
Doesn't sound like you have the qualifications or experience for the task. You should prepare a duty spec and let experienced vendors design and supply the vessel.
#3 Process Engineer 90
Process Engineer 90
  • 9 posts
Posted 14 February 2017 - 06:29 PM
Thank you very much for your valuable answer. But I expected something like references or equations not leave that because you are not qualified.
Edited by Process Engineer 90, 14 February 2017 - 06:33 PM.
#4 Nikolay_
Nikolay_
  • 169 posts
Posted 15 February 2017 - 04:06 PM
Could you please explain what is test separator for? Recently I saw the interesting thread at student forum. It's named "Knock Out Drum Sizing". Try it.
#5 Chemitofreak
Chemitofreak
  • 292 posts
Posted 16 February 2017 - 05:28 AM
Test separator is a three phase separator provided nearest to the oil wells. Test separators are provided to analyze or to test the crude quality, gas to HC ratio etc. etc.
A KOD is also a separator, but is generally provided for two phase separation i.e. liquid & gas e.g. Compressor KOD & Flare KOD.
#6 Process Engineer 90
Process Engineer 90
  • 9 posts
Posted 16 February 2017 - 11:12 AM
Thanks dears
#7 Nikolay_
Nikolay_
  • 169 posts
Posted 16 February 2017 - 03:58 PM
Chemitofreak,
Thank you for explanation.
