Now a days, we are having a problem in our refinery regarding heater stack flue gas analysis. It is very strange to have h2s in stack flue gases as it is an oil fired heater. I can not disclose quantity of h2s in the flue gas as it is confidential.
I did an extensive search to trace the origin of the culprit but could only find it in the storage but in vapor phase. Fuel oil is mantained at a temperature of 60 oC in the tank and then it fired with the excess air in the forced draft box type heaters. Is it possible that vapor phase h2s condenses during transfer to heater and then it vaporizes? But the pipeline and tank is completely insulated and heat traced with steam.
Did any one of you experience the same problem, then please guide me in this respect? Your valuable suggestion will be very much helpful to me.
Qasim
Edited by vectorangel, 27 February 2017 - 10:49 AM.
