hi, i have been in exposure with oil refineries since i was 18 yrs old and it has been almost 20yrs. a very common and unanswered mechanism is the corrosion in flue gas stacks of fired heaters especially having an air preheater heated by flue gas. i have seen oil professionals banging their heads when they find preheaters and stacks getting corroded due to sulfur compounds. this is when i find them referring to dew point curves of H2S. which i think is futile as there is always corrosion even when the flue gas temperatures are more than dew points of H2S for the current concentrations of H2S. they keep repeating the mistake with great ignonimity on depending on H2S dew point curves even when they are pointed that the curves are very incomplete.
please comment
