Hello Everyone,
We have a problem with steam reboiler pass partition plate which was bent. We saw that when we pulled it out for cleaning as it was fouled.
As per RCA the partition plate was damaged because of high dP however it can't be proven due to no pressure indicators available up and downstream of the steam reboiler.
Can it be explained by theory or identified by other parameters if the design is such that steam reboiler tube side has a HP steam flow (40barg) in and condensate stream out connected to the condensate pot which has a balance line connected to the inlet HP steam line.
Thanks.
Berik
