Hello, I am having trouble trying to converge a Linde double column arrangement in Hysys. Since I have linked the common heat exchanger between the HP and LP columns I am unable to converge the LP column aiming to achieve 99% LOX. I have tried changing solvers, changing many specifications and adding balance blocks to no avail. I have noticed several simulations of ASUs have been posted on the site but most are incomplete so I have no solid reference flowsheet. Any advice and help on converging my simulation would be massively appreciated. Thanks.
I have attached the hysys file as .xml so it should open in most versions
