hi engineers
What are the consequences when using a heat exchanger with a temperature cross and a correction factor less than 0.75( It can be used if it gives the desired temperatures?)
thank you
Posted 30 March 2017 - 03:03 PM
hi engineers
thank you
Posted 30 March 2017 - 03:18 PM
It depends whether you are the owner or an engineering contractor working for a client.
