HEllo friends ;
I'mw ondering if anyone could explain why a horizontal separator is choosen when we have more more liquid flow rate and vertical separator for more vapor flow rate ?
Thanks a lot !
Regards !
Posted 03 April 2017 - 04:05 AM
HEllo friends ;
Thanks a lot !
Regards !
Posted 03 April 2017 - 11:11 AM
It's usually a matter of cost. You can compare the different options with software at my site. Just Google my name. For the horizontal orientation you must use the example you can access from the Home Page.
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
