Design Of Helical Coil Heat Exchanger
#1 Sakthi Vel
Sakthi Vel
  • 7 posts
Posted 05 April 2017 - 06:53 AM
Dear Experts,
Can anyone share the design of helical coil heat exchanger calculation.
#2 srfish
srfish
  • 408 posts
Posted 05 April 2017 - 09:51 AM
Is the coil in a vessel  that has agitation?
#3 Napo
Napo
  • 350 posts
Posted 06 April 2017 - 09:13 AM
Sakthi Vel,
You can search in this forum "Helical Coil design", you will found information about your question.
Napo.
#4 Art Montemayor
Posted 06 April 2017 - 11:26 AM
Sakthi Vel,
SRfish brings out an important point before going any further.
Unfortunately the term “spiral” is used frequently to mean various forms of pipe or tubing coils.  Sometimes what is meant is the term “helix”.  Is that your case?  You have to be SPECIFIC in describing what you mean or have.  Otherwise, we waste a lot of valuable time and effort on the part if our members.  Please refer to the attached documents to see the difference between two types of heat exchanger tubing configurations.
I have designed and built both the helix and spiral type of heat exchanger in the field, using them in relatively small size applications (<50 ft2).  I’ve used them as preheaters, gas-to-gas exchangers, compressor intercoolers, and sample coolers.  I have uploaded a lot of material and literature in our Forums through the years and you can find it using our SEARCH engine.  I can upload information in this thread, but you must be specific about your application.  For example, answer SRfish’s question regarding whether the coil is in a tub or vat and is agitated.  These details all make a big difference in how your query is answered.
Await your input and response.
Attached File  Helix or Spiral.docx   81.15KB   792 downloads
Attached File  Graham Heliflow Sizing.pdf   2.08MB   1103 downloads
