Posted 07 April 2017 - 03:17 AM
For this Prode in his manual proposes PutN() functions, but this function is missing in "properties1".
I think that in the free version this function is not available but that this is included in ppp.dll.
Because of this any idea to do this?
Someone know the variable to PutN(?,?,?) I think that is possible put this function in vba and call to ppp.dll but I need the variables that uses PUTN.
thank in advance
Posted 07 April 2017 - 07:56 AM Best Answer
not all the methods exported by Prode Properties library have definitions in Excel VBA I think because of Excel VBA limits with strings,
for Excel VBA strings Prode includes a few specific methods as MStrN(),
the method putN(int stream, char *name) is available for all languages and requires a ANSI null terminated string,
to pass a ANSI C string from Excel VBA simply declare it put a 0 end and pass the pointer as for MStrN(),
Public Declare PtrSafe Function PutN Lib "ppp.dll" (ByVal str As Long, ByVal name As String)
however take care to avoid errors with Excel which is very sensible,
for these reasons I use only the predefined methods in my Excel VBA pages (ok, no problems with other languages)
Edited by serra, 07 April 2017 - 08:22 AM.
Posted 07 April 2017 - 10:19 AM
Your answer was very useful for me because this answer brought me to the resolution of my problem
In any case I finally do this with the next modifications in vba
Declarations
Public Declare PtrSafe Function putN Lib "ppp.dll" (ByVal str As Long, ByVal Pos As St
ring) As Long 'metido por mi
And the next code
Dim buzz As String * 100
buzz = Left(Cells(2, 2), 50)' only define the string
res = putN(stream, buzz)'stream is the number of stream in prode editor
Missing Data For Stream ComponentsStarted by Guest_Desmith475_* , 07 Aug 2025 |
Aspen Plus - Is There A Function To Determine The Relative Quantites OStarted by Guest_EdJones90_* , 11 Sep 2020 |
Types Of Cyclone Function In Large Flow RateStarted by Guest_alaasleem2026_* , 03 Sep 2024 |
Minimizing The Objective FunctionStarted by Guest_chemtoli_* , 06 Jun 2023 |
Find The Lowest Delivering Cost By Minimizing The Objective FunctionStarted by Guest_chemtoli_* , 30 May 2023 |
