What are the criteria that have to be considered during "under flow" or "over flow" selection for glove type control valve?
Many thanks
Shahidul
Posted 16 April 2017 - 06:13 AM
Many thanks
Shahidul
Posted 17 April 2017 - 04:23 AM
I guess by overflow and underflow you mean maximum flow and minimum flow:
a) Max Flow = Design Margin x Normal Flow (Design Margin is generally 10% for process and 15-20% for utilities)
Min Flow = Based on Turndown requirement
Posted 17 April 2017 - 05:32 AM
Or you refer to "flow-to-open" and "flow-to-close" terminology? If yes, read more at https://blog.craneen...ow-to-close-ftc
Posted 17 April 2017 - 06:54 AM
Thanks for your answers.
Although I don't clear about the answer from chemitofreak.
According to the reply of Zauberberg, yes you are right. I was asking about that.
Although I had visited that site before it doesn't clearly convey the message of selecting right flow direction for different process criteria.
I would like to have some information that would lead me to choose right flow directions from different considerations.
Many thanks.
Posted 17 April 2017 - 08:52 AM
Posted 18 April 2017 - 10:22 PM
Thanks Zauberberg for your co-operation by sharing that file.
It really helps.
Posted 19 April 2017 - 04:38 AM
The last few paragraphs of the attached text provide direct answers on your question (see also below).
Following the incremental safety logic, you would choose a flow-to-open arrangement for e.g. pressure control valve, and a flow-to-close arrangement for e.g. hot oil flow to reboiler.
If there are dedicated safety instrumented system (SIS) valves for isolation/venting, following this philosophy may be an unnecessary overkill - it all depends on the actual facility and the associated risks. I personally see these arrangements as important safety features only in cases when there are no dedicated isolation/blowdown valves, operated by the SIS.
open-and-close.png 29.46KB
5 downloads
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Teg Dehydration Stripping Gas Flow RateStarted by Guest_SidRah_* , 20 Aug 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
