Joule Thomson Valve Cost Estimation
Posted 18 April 2017 - 04:45 PM
What are the necessary parameters to estimate Joule Thomson valve cost?
Can we consider it as a control valve?
What is the range of cost for Joule Thomson valve reduce the pressure of (1.5MMscfd)from (14 bar) to (6bar) ?
Your positive response is highly appreciated.
Best Regards,
Posted 18 April 2017 - 07:24 PM
Please be realistic and rational.
Do you expect our members to calculate the correct size of your valve and then give you a cost estimate? We don't even know what country, economic and political situation you are in. What currency are you dealing in?
Supply our members with a size and type, and perhaps some member will offer a guess.
But if you really need a realistic and actual estimate, consult with a valve manufacturer. (Unless you are a student who is trying to get answers to an academic assignment).
Posted 19 April 2017 - 07:19 PM
Of course, there is no such thing as a Joule Thompson valve. Thompson is the guy who first described the thermodynamics of reducing a stream pressure with hardware such as a valve.
Posted 30 April 2017 - 02:41 AM
If you don't have an in-house estimator (pretty handy!!) , or previous invoice archive for similar valves purchased, the best thing to do is to get in touch with a vendor. Specify the size of pressure reducing valve you require and ask for an estimate. If you are a student, your lecturer should have provided you with the sufficient tools / references to estimate a cost.
Edited by ChemEng01, 01 May 2017 - 11:59 PM.
Posted 08 May 2017 - 02:34 AM
1- joule Thomson has discussed in thermodynamic but this phrase sometimes is used in industrial applications related to pressure drop, like process gas pressure drop valves known as JT or Joule Thomson valves.
2- if you look for a precise cost the best way is contact with a valve manufacture. For approximate purposes it can be get from Previous Project information(if available) or software( like Aspen Economic Evaluation...).
Posted 14 June 2017 - 06:32 PM
To be fair the question was 'what are the necessary parameters'.
So you could start by thinking of size,pressure class, materials of construction, what kind of actuator do you want, does it need to be ATEX rated?, does it need any special IP rating? Acoustic limits? Do you need the valve expediting?
Of course - do you have a certain valve type in mind?
A JT valve can be considered a control valve (across which a Joule Thomson expansion is taking place).
Safety ValveStarted by Guest_guoyinyanliner_* , 11 Oct 2026 |
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
