I am simulating a lng/ngl plant by using aspen hyssy. I want to know how can i optimize the single mixed refrigerant cycle with Hysys?
And how can i choose the best mole fraction for refrigerant?
Thank you for your guiding
Posted 05 May 2017 - 01:54 AM
Posted 05 May 2017 - 07:09 PM
It sounds like you skipped all the basics of simulation models. And you are not likely to get someone to supply a simulation for you. What you ask for is a lot. So, focus on what you need.
Posted 06 May 2017 - 10:36 AM
thank you Bobby
can i insert mole fraction as a variable in Hysys?
Posted 06 May 2017 - 11:21 AM
You should search the web for help. It seems that you are undertaking a task for which you are not prepared. Are you a student?
Posted 07 May 2017 - 01:06 AM
yes i'm student
thank you
Posted 18 October 2017 - 08:25 PM
The gas being liquefied has a specific cooling curve, for best efficiency your MR cooling curve will need to closely match it (this will produce the smallest gap between the cooling curves)
However a single MR system has to combine the full cooling and liquefaction requirements into a single composition mix, (noting that this composition needs to be maintained and reproduced in an operational sense).
Optimization of MR composition is only done when you factor in limits and constraints.
The main one for LNG facilities is power i.e. gas turbine driving compressors.
As your MR composition changes this directly impacts the power requirements of the compression.
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Problem With Writing Offshore Plant Design PfdStarted by Guest_Doneisbetterthenperfect_* , 06 Dec 2023 |
Benfield Solution For Ammonia PlantStarted by Guest_Chemist Ahmed_* , 03 Dec 2023 |
