Situation: I have a brown field project in which a RV is installed downstream of a compressor. There is a bit of distance between the compressor and the piping location on which this RV is installed. The design case of the RV is blocked flow (of a downstream control valve). Our goal is to re-evaluate the RV for new flow rates.
My Assumption: I suppose this RV is there to protect the piping downstream of the control valve and also to protect the compressor in case the discharge pressure of the compressor exceeds the set pressure of the RV.
Question: I think, anyway, the losses from the compressor to the RV inlet should be calculated to make sure the pressure in the discharge of the compressor doesn't exceed its design pressure, but my question is that should I start the calculation of the 3% inlet losses rule (for RV) from the nearest piping header tee (on which this RV is installed)(Point 2 in the attached file) to the RV inlet OR from the compressor discharge (Point 1 in the attached file) to the RV inlet? My guess is that the nearest piping header tee should be the start point for this calculation, but wanted to double check that.
Attached is a scheme to make it clear.
