Fire Supression System For Horizontal Tanks
Posted 17 May 2017 - 11:35 PM
I am currently working on design of a fire fighting system for a fuel storage terminal. So the terminal contains buried horizontal fuel storage tanks. In my review of several NFPA codes I did not come across any information on horizontal tanks. Kindly, refer any relevant nfpa, ip or api standard or share your experience. Any help would be appreciated.
Stored fuel is gasoline (Class I)
Posted 20 May 2017 - 01:34 AM
Please refer OISD 116
Posted 20 May 2017 - 06:22 AM
Refer the attachment in post #7 in the link below for horizontal. The attachment shows the sketch for water spray for horizontal tanks as given in NFPA 15.
https://www.cheresou...-in-tank-farms/
Posted 21 May 2017 - 08:09 PM
The key is that they are buried. I don't recall having provided fire protection for buried tanks.
Posted 21 May 2017 - 11:43 PM
Bobby,
Top portion of the buried tank has all the pipe and instrumentation connections and is exposed. Any exposed portion requires fire protection. Hope this clarifies fire protection requirement for such a tank.
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Fire Case Psv For Lean Glycol FilterStarted by Guest_Arsalan_1992_* , 08 Nov 2025 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
