Flue Gas Quench Tower Design
quencher heat transfer
13 replies to this topic
#1 Keyboard101
Keyboard101
Posted 30 May 2017 - 11:46 PM
I am designing a Quencher Tower for Flue Gas for of MSW Incineration Plant. The flue gas need to be cooled down from 850 - 950 deg C to 150 - 250 deg C. The quenching agent is water at 30 deg C. The flow is co-current flow with dry bottom vessel. At the moment, we have calculated the diameter to be 2.0m. However, I have no idea how to calculate the height of the tower.  :wacko:
  • 7,058 posts
Posted 31 May 2017 - 12:33 AM
Did you try Google ? I've added a document from my friend's library :)
http://www.chemicalp..._whitepaper.pdf
Hope this is helping you.
#3 Joan Pinol
Joan Pinol
Posted 27 September 2022 - 08:11 AM
Hello, I have the same problem, and the link does not work properly. in addition, i have searched in google and I didn't find anything
thank you in advance
#4 latexman
  • 1,929 posts
Posted 27 September 2022 - 09:01 AM
I searched using "gas-water direct contact heat transfer" and got 430,000,000 hits.  That's no guarantee any of it is useful, but . . .
There appears to be pertinent information in the "Liquid-Gas Systems" chapter in Perry's Handbook.
#5 horatorres
horatorres
  • 88 posts
Posted 28 September 2022 - 08:09 PM
Quenching is a fast process, usually you consider  a 5 theoretical trays space to find the upper size as a preliminary approach.
Check the link,
https://www.academia...Quencher_Design
There are several design considerations, I found some very easily in google.. write in search  hot quench tower design, and find the one close to your case
Horacio
#6 horatorres
horatorres
  • 88 posts
Posted 28 September 2022 - 08:16 PM
at home there is a Excel sheet
https://www.cheresou...esulfurization/
#7 breizh
  • 7,058 posts
Posted 02 October 2022 - 06:57 AM
Pay attention to the document shared from academia, errors in the calculation of Delta T ml (counter current contactor not co current), term missing in the calculation of Z^0.5   and mix up of units.
#8 breizh
  • 7,058 posts
Posted 05 October 2022 - 10:25 PM
In addition to my previous reply consider this paper where the correlation is in SI units with an example.
#9 rajeshp79
rajeshp79
  • 4 posts
Posted 06 March 2023 - 05:17 PM
Hi Breizh, which paper you are referring to? Where is the correlation in SI unit as the academia one units are not correct and tried several ways but answer doesn't match.
#10 breizh
  • 7,058 posts
Posted 06 March 2023 - 06:08 PM
Take a look at this spreadsheet .
#11 rajeshp79
rajeshp79
  • 4 posts
Posted 07 March 2023 - 05:28 PM
Hi Breizh,
Your spreadsheet is very helpful. Thank you for sharing. I have a quick question on pressure drop calculations. Normally water flow is counter-current and pressure drop certainly should be less than a packed bed and it is easy to estimate the pressure drop across the packed bed. For such a spray tower do you recommend any particular correlation for pressure drop calculations?
#12 breizh
  • 7,058 posts
Posted 07 March 2023 - 08:09 PM
The head loss of this type of equipment is very minimal, you need to focus on the head losses of the nozzles (see vendor's catalogue).
https://www.pnr-fran...CTG_SH07_BR.pdf
To me this is not a concern.
Another good reference to support your work on heat transfer and direct contact liquid gas.
#13 breizh
  • 7,058 posts
Posted 23 March 2023 - 06:20 AM
You need to review your calculation, figures are weird.
#14 rajeshp79
rajeshp79
  • 4 posts
Posted 23 March 2023 - 08:53 AM
I agree with you. I performed sensitivity analysis and figured out the issue.
