Hello everyone,
Recently, I started to use HTRI for designing plate heat exchangers and I've got some questions about it.
1- What is the difference between Design option and Grid Design?
2- In the plate types part, what is the advantage of plate type 1, plate type 2 and so on?
3- Is it possible to rate and design our desired geometry with HTRI?
I used to use HTFS, I wanna know what things HTRI have for designing PHEs that HTFS doesn't?
Providing any tutorial, advice,...would be so much appreciated.
(My version is v6)
Designing Phes With Htri
Started by Mina_4, Jun 05 2017 12:07 PM
htri phe plate plate heat exchanger design
Posted 05 June 2017 - 12:07 PM
Designing A Packed Distillation ColumnStarted by Guest_funkysticks_* , 18 Oct 2023 |
Htri SimulationStarted by Guest_Santoso13_* , 12 Mar 2023 |
Designing The Internal Dimensions Of The Grease TrapStarted by Guest_rezagholipoor_* , 10 Dec 2022 |
Fire Case Psv DesigningStarted by Guest_tsaravanan1976_* , 24 Nov 2022 |
Pct Tube Removed Result In HtriStarted by Guest_cincao_* , 29 Oct 2022 |
