Block Valve And Check Valve In Flare Ligne
Posted 07 June 2017 - 12:35 PM
Posted 08 June 2017 - 07:38 AM
In your sketch, no PSV is indicated. Is it true?
It means that the pressure at the bypass line is too high to be released into the flare header.
What is the pressure at by pass line?
Posted 09 June 2017 - 06:07 AM
hello mahdi;
Posted 11 June 2017 - 09:02 AM
In general, you are not allowed to connect a get a branch line from the by-pass to the flare unless the valve is locked open.
Posted 11 June 2017 - 12:50 PM
Hello Mahdi;
thanks for your replay ;
this by-pass it will be used only during LP and MP compressor shudown. for the first startup years but after it will closed.
can you propose others configuration to connect to the flare.
